Hi guys
I have tried to setup my hassio with help of this video
but i dont get forwarded to the raspberry with hassio but to my modem instead?
Hi guys
What does your home networking look like? do you have an all in one modem/router or a separate modem and router.
What port are you trying to run HA on? Does your ISP block this port?
Did you set a static IP on the device that HA is running on?
Are you sure you got your port forwarding correct?
So many things can go wrong, that I’d go back through and double check that you got everything correct.
Hi
Ty for your reply
My setup is like
Modem and a separate router
Port is static and reachable from extern.
But when I go to the address set as domain from DuckDNS I will forwarded to my modem page.
Are you specifying the port you are forwarding in the address.
Yes that’s correct tried with http, https and without
You are adding the port to the end right?
Can you share the port forward settings on your router?
Why are you not answering this question?
Paste the web address you are using to access.
Are you trying to access from inside your network or from outside. These are two very separate issues.
You are not forwarding 8123 on your router. You are forwarding 443. (At least that is what I read from your foreign (to me) language pic.
So you should look to connect to
You are an hero!!!
Hell yeah!
The fowarding was set correcty! but I did not enter te port after the duckdns domain
