Duck DNS With IPV6 & DS LITE on AVM FRITZBOX
Hi there,
my provider suddenly switched to IPV6. Since then, external access no longer works (DUCKDNS). Perhaps someone has a similar problem and was able to solve it somehow? I am grateful for any help.I use a Fritzbox 6591 as a router.
Thank You
Why don’t you use the external IPv6 address of your Homeassistant device instead of the DualStack Lite IPv4 address?
That should be possible with DuckDNS.
Of course, the appropriate configuration also depends a bit on the installation type of your HA system :wink:
Hi Simon
Thank you for your answer. I have now registered and updated the Ipv6 at DuckDns. I don’t get any outside access to songs.
Do you have an example of how I have to configure something?
What exactly do you mean by “songs”?
As I said, before we can give you any hints about a possible configuration, we would need to know your installation type of Home Assistant :wink:
Since you use a Fritzbox, I assume you come from the German-speaking area?
If you want, you can also send me a PN in German. This might make the communication a little easier.
Greetings
