I’ve been searching for a tutorial without success - I can access HA via https but can’t access it local via HTTP. I need the last to be able to use some integrations (e.g. Ecowitt). How do I make it possible to both be possible to access HA via http on my local network and https (duckdns)?
The only way to do this is with a reverse proxy like NGINX or Caddy. I don’t know the details but there are plenty of posts on the forum about it. There are reverse proxy addons for HA OS.
Basically it works like this:
Encryption is handled by the reverse proxy, but I’m not sure where the dynamic DNS is managed from.
Agree, plenty of posts telling “use NGINX” and I have installed it but don’t know what then to do.
Try these instructions:
Or these ones:
I have now followed both guides but without luck. I get the local access (without http) but can no longer log in from outside (my duckdns domain). The browser can’t get a secure connection to the server.
Edit: After waiting a small time it works - might be some DDNS that have to be updated. Thanks for the help.
After got everything working with DuckDNS and can access your HA from outside.
Install Nginx addon in HA
change the config
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
# base_url: example.duckdns.org:8123
in nginx setting domain is your duckdns domain, and port 443 (or which ever port you forward from the router to) i forwarded 8123 to 443
note i have to comment out the duck dns one
see if that work
I followed below step-by-step:
but getting this:
[17:11:48] INFO: Running nginx...
stat: can't stat '/ssl/fullchain.pem': No such file or directory
[17:11:48] INFO: Service nginx exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service crond: stopping
[17:11:48] INFO: Service crond exited with code 256 (by signal 15)
s6-rc: info: service crond successfully stopped
There is no step telling how to create ssl/fullchian.pem
Can someone help me on this?
