DuckDNS addon constantly stops without reason
I am curious if anybody else has encountered this problem (referenced as this Github issue)? If I go into hass.io in the left panel and start the DuckDNS addon, go to overview and then back to the addon page I can see that is has stopped again.
Most of the time it is not a problem, but ever so often (daily or semi-daily) my clients lose access to the hass.io server on my Raspberry Pi 3. When that happens, I have to ssh into hass.io and restart the server. I am not entirely sure that it is related to the issue in question, but it sure seems plausible.
For a start I would install this custom sensor:
Do you monitor other system stats like memory, cpu use etc…?
This is not normal:
…(daily or semi-daily) my clients lose access to the hass.io server on my Raspberry Pi 3. When that happens, I have to ssh into hass.io and restart the server.
I monitor memory use and disk use, but not cpu, but they are not showing anything unusual. Disk use is at about 12% and memory at ~30%. I am using an official 2.5Amp RPi charger, so unless there is something faulty with the hardware, current shouldn’t be a problem.
The DuckDNS log show nothing, but I will also look at homeassistant.log the next time client access stops.
My DuckDNS certificate has expired 3 days ago at not been renewed automatically by this addon.
Found this in the DuckDNS log today:
# INFO: Using main config file /data/workdir/config
ERROR: Lock file '/data/workdir/lock' present, aborting.
What does that mean?
I uninstalled and reinstalled the addon, and after that it worked!
