DuckDNS addon is not updating IP. Output from the log is:
Sat Mar 23 10:09:37 CET 2019: KO
DuckDNS addon configuration:
Note that I intentionally don’t want DuckDNS to generate SSL certificate. I have valid cert already generated by Let’s Encrypt addon and placed in default /ssl/
Anyway, certs are not the point here, just updating the IP address of DuckDNS domain.
"lets_encrypt": {
"accept_terms": false,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
"token": "SECRET-DUCKDNS-TOKEN",
"domains": [
"ABC-MY-DOMAIN.duckdns.org"
"seconds": 300
I have also setup http: in Home Assistant configuration.yaml as below, although I’m not sure if it’s relevant for updating IP:
http:
base_url: https://ABC-MY-DOMAIN.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Anyone encountered such problem?
I had no issues at all with duckdns script running on Hassbian, before migrating to hassio.
