I tried to use DuckDNS addon in Hass.oi.
- My addon config is:
“lets_encrypt”: {
“accept_terms”: true,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
“token”: “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”,
“domains”: [
“xxxxxxxxxxxxxxxx.duckdns.org”
“seconds”: 300
- And i uncomment http section in configuration.yaml:
http:
base_url: xxxxxxxxxxxxx.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
- I make port forwarding for 8123 port
I copy xxxxxxxxxxxxx.duckdns.org:8123 in adress line my browser. And I see: “could’t connect”
If i typing only xxxxxxxxxxxxx.duckdns.org i’m redirected to the web interface of my router.
Please help me!!!
What if you type https://xxxxxxxxxxxxx.duckdns.org:8123/
in your browser?
By the way, you do not need to store secret information in your configuration.
Which works with your internal ip address? http://[ip address]:8123
or https://[ip address]:8123
If the second one works, a certificate error is normal and expected.
Https works with internal ip, http not work
It is good https works. That indicates the DuckDNS addon is configured correctly.
Port Forwarding on your router would appear to be the issue.
On your computer, if you type nslookup xxxxxxxxxxxxx.duckdns.org
do you get an ip address returned? If not that could be an issue too, but not too likely.
It returned ip address of my router -192.168.0.1. And next my external ip
It should show your external ip address.
It returned my external ip 90.xxx.xxx.xxx
Try a different browser? Sometimes Chrome’s caching behavior gets in the way.
Some routers do not support HAIRPIN NAT, so you may not be able to get to it.
I try it in Opera browser too, still not work. I check port 8123 in 2ip.ru, it displayed what port 8123 is opened
