Using latest HA - Home Assistant 2022.7.5 - I installed duckdns add on and log shows it appears to be working, but it has not generated certs in /ssl folder. If I try to add documented http: settings to configuration.yaml it gives me the error when trying to restart
The system cannot restart because the configuration is not valid: Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/fullchain.pem'
not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/privkey.pem'. (See /config/configuration.yaml, line 13).
I have installed letsencrypt also but I don’t believe it’s needed and I have not set it up.
I used to have this running fine on old pi3b, but this is a brand new install on pi4
