I try to get working the duckdns add on.
I try to follow the instruction page at https://www.home-assistant.io/addons/duckdns/
I added these lines to my configuration.yaml file:
http:
base_url: mydomain.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
When I validate the configuration file I get this error:
Invalid config for [http]: not a file for dictionary value @ data[‘http’][‘ssl_certificate’]. Got ‘/ssl/fullchain.pem’
not a file for dictionary value @ data[‘http’][‘ssl_key’]. Got ‘/ssl/privkey.pem’. (See /config/configuration.yaml, line 26). Please check the docs at https://home-assistant.io/components/http/
This is the configuration of the add-on
“lets_encrypt”: {
“accept_terms”: true,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
“token”: “My-duckdns-token”,
“domains”: [
“mydomain.duckdns.org:8123”
“seconds”: 300
This is an excerpt of the add on logfile:
Thu Mar 7 14:55:46 CET 2019: KO
Thu Mar 7 15:00:47 CET 2019: KO
Thu Mar 7 15:05:48 CET 2019: KO
Thu Mar 7 15:10:49 CET 2019: KO
Thu Mar 7 15:15:50 CET 2019: KO
Thu Mar 7 15:20:51 CET 2019: KO
Thu Mar 7 15:25:52 CET 2019: KO
Thu Mar 7 15:30:53 CET 2019: KO
Thu Mar 7 15:35:54 CET 2019: KO
Thu Mar 7 15:40:55 CET 2019: KO
Thu Mar 7 15:45:56 CET 2019: KO
What is going wrong?
