DuckDNS down
Cannot open Duckdns.org seems down. Anybody else?
Me too, DNS servers are not currently resolving the domain duckdns.org
Wait and see…
Same problem here :pensive:
It’s down here too, can’t connect to my hassio setup at this point. I thought my Pi was broken or my network config was acting stupid or something…
Working again for me now
As we speak, I too can connect now again…strange :thinking:
Works again, lately it’s down a lot :thinking:
Cloudflare for the win. Plenty of extra cool useful features to play with it, all free. Just need to get your own domain.
And needless to say it’s rock solid and FAST, 10% of the web traffic goes through Cloudflare so you can have an idea of their success.
Faced the same issue a couple of time today, I suspected my raspberry Pi, then now it definitely Duckdns down and it can’t resolve my domain.
I’m interested in this :slight_smile:
How do you link your dynamic IP with a subdomain of yours?
My only guess is using the remote access provided by NabuCasa and an A record, right?
Is there a dynamic DNS way?
Can you point me into the direction on how to use CloudFlare and SSL? I want a stable DNS solution for in the future now that I will experienced this with DuckDNS.
Edit: found it: Hass.io Add-On: letsdnsocloud - Custom Domain SSL & DDNS
Same here. I would like to know how this is done as well
Hi, same problem in Paris, France :sob:
Hi all, same problem in Thessaloniki, Greece.
since early this morning.
Thought it was my set up cause i was experimenting with adguard, but as it seems is not my fault. :slight_smile:
Found it: Hass.io Add-On: letsdnsocloud - Custom Domain SSL & DDNS
Check out the letsdnsocloud add-on.
Re, It’s working again for me ! :smiley:
There’s not much to it, there’s a component to update the Cloudflare DNS records you want:
It updates every hour, but you can create an automation that on state change of your IP entity it will run the update records service. Automations do not get any simpler than that.
Here’s a post I’ve made regarding the setup:
https://community.home-assistant.io/t/reverse-proxy-cloudflare-access/159182/2?u=gurbina93
dang. duckdns has been very spotty this week. haven’t decided if i should stick with them and donate to them in the hopes that it is resolved or switch now to another provider like cloudflare
