Hi, yes external 443 to 8123 to my local home assistant address. Timeout after a while is the only result I get…
Also tried 8123 to 8123 with same result.
Don’t know if this even is a clue… when browsing to xxxxx.duckdns.org it’s a timeout after a while, doing the same with xxxxx.duckdns.org:8123 it immediately disconnects.
Ehm I feel a bit stupid here I just typed xxxx.duckdns,org:8123 without https, that didn’t work. adding it worked fine. was sure that it would redirect to https…
Is there a way to redirect to https? And, is there a way to skip the port in the URL?
