DuckDNS Hassio Issues
Hi all,
I’m having an issue with the duckdns addon in hassio. I cannot connect to my instance externally without getting a SSL error in the browser.
I have setup duckdns, installed duckdns addon and input my configuration including the token and hostname from duckdns:
lets_encrypt:
  accept_terms: true
  certfile: fullchain.pem
  keyfile: privkey.pem
token: XXXXX-XXXXXX-XXXX-XX
domains:
  - MY_DUCK_DNS.duckdns.org
aliases: []
seconds: 300
Here’s the log from DuckDNS addon:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
# INFO: Using main config file /data/workdir/config
+ Generating account key...
+ Registering account key with ACME server...
+ Fetching account ID...
+ Done!
[23:01:25] INFO: OK
MY_IP
NOCHANGE
 + Creating chain cache directory /data/workdir/chains
Processing MY_DUCK_DNS.duckdns.org
 + Creating new directory /data/letsencrypt/MY_DUCK_DNS.duckdns.org ...
 + Signing domains...
 + Generating private key...
 + Generating signing request...
 + Requesting new certificate order from CA...
 + Received 1 authorizations URLs from the CA
 + Handling authorization for MY_DUCK_DNS.duckdns.org
 + 1 pending challenge(s)
 + Deploying challenge tokens...
OK + Responding to challenge for MY_DUCK_DNS.duckdns.org authorization...
 + Challenge is valid!
 + Cleaning challenge tokens...
OK + Requesting certificate...
 + Checking certificate...
 + Done!
 + Creating fullchain.pem...
 + Done!
[23:06:53] INFO: OK
Forwarded port 443 to 8123 on my router (pfsense), confirmed open using port checker tool
Input my external ip into Configuration - External URL
https://MY_DUCK_DNS.duckdns.org
When attempting to access https://MY_DUCK_DNS.duckdns.org I get the SSL error
I’m not sure what else to do, seems as though the ssl cert is not working?
Any ideas?
Silly me, didn’t put the http configuration in. I assumed that because base_url is not needed then http wasn’t.
Working now and can access externally
b756f0ed-4304-47c3-b760-add1abb63a1a
For everyone still searching for the solution to this problem. I wrote a detailled guide to the solution:
