hassio .62.1. Read dozens of forum posts and still not able to get duckdns working. Need step by step instruction from somebody who has this working on hassio .62.1 only.
Cannot get duckdns add on to start. Will not allow me to save anything but “accept” true.
Save is grayed out after adding api key and domain.
The save key is disabled when there is a syntax error in the configuration. Double check all parentheses, commas, quotation marks, backslashes.
If you need advice post your duck dns config here formatting it as stated in the blue box on top of the thread.
Thank you very much !! After days of trying this just like you recommended I sat down this morning and ran through Tom’s excellent tutorial and got it working in 5 minutes on the first try. Not sure what I was doing wrong before this morning? Thanks again. -Joe
