I ve a problem with LetEncrypt.
I installed duckdns add on, and all work fine while i use http whit my personal duckdns address
Now, for some configuration, i need https protocol, and follow the guide for LetEncrypt.
So, I add my token, my address.duckdns.org and change on true bolean value add this line in the configuration.yaml file
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
from this moment, when I restart home assistant, the application go in crash and never restart the app
this is my configuration.yaml
and this the answer of broswer (with local ip and with duckdns domain)
For restarting Home Assistant, I have to connect whit ssh to local ip, delete that lines whit terminal, and when I reboot Home Assistant return to work.
Someone had some problem and solved it can help me?
Thank you so much
