When i navigate to my HA instance (https://xxx.duckdns.org:8123) i get an SSL error (“The date of the Home Assistant certificate is invalid”). Upon inspection of the certificate it appears that the certificate has expired:
However, the certificate seems to have been renewed, as per the DuckDNS log:
DuckDNS log:
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[13:28:58] INFO: OK
xxx.xxx.xxx.xxx
NOCHANGE
[13:28:58] INFO: Renew certificate for domains: xxx.duckdns.org and aliases:
Processing xxx.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Nov 27 17:04:44 2023 GMT (Longer than 30 days). Skipping renew!
Both files in the /ssl/ folder (fullchain.pem and privkey.pem) have a timestamp of Aug 29 2023, 11:04, so the cert seems to have been renewed on August 29.
Here’s the DuckDNS config:
domains:
- xxx.duckdns.org
token: xxx
aliases: []
lets_encrypt:
accept_terms: true
algo: secp384r1
certfile: fullchain.pem
keyfile: privkey.pem
seconds: 43200
and the configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
homeassistant:
packages: !include_dir_named packages
logger:
default: warning
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
So there seems to be a discrepancy between the ssl certificate pulled by let’s encrypt and the one the browser sees? Any ideas why this might be the case?
thank you.
