Hey Guys,
I have tried getting this add on to work for ages now but it never seems to work for me. I think the SSL works because if I try to access my Hass.io instance locally via IP I get the warning about the SSL certificate not matching. However, if I try to use the address I have configured in DuckDNS and my config.yaml it seems to fail (But does reach my router).
Can someone tell me where I have gone wrong, please?
config.yaml:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: https://12345.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
DuckDNS addon:
"lets_encrypt": {
"accept_terms": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
"token": "12345.token.goes.here",
"domains": [
"12345.duckdns.org"
"seconds": 300
My router portforwarding configuration:
