DuckDNS/Let'sEncryt Error
Hi guys,
I’m trying to install DuckDNS addon in hassio, but got error (I also found this error in old topic, but I did’nt found any solution for my case).
Here my configuration :
  "lets_encrypt": {
    "accept_terms": true,
    "certfile": "fullchain.pem",
    "keyfile": "privkey.pem"
  "token": "XXXXXTOKENXXXXX",
  "domains": [
    "XXXXX.duckdns.org"
  "seconds": 300
DuckDNS seems good :
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[22:31:29] INFO: OK
PUBLICIP
NOCHANGE
Processing XXXXX.duckdns.org
 + Checking domain name(s) of existing cert... unchanged.
 + Checking expire date of existing cert...
 + Valid till Apr 25 11:16:28 2020 GMT Certificate will not expire
(Longer than 30 days). Skipping renew!
[22:36:33] INFO: OK
PUBLICIP
NOCHANGE
configuration.yaml
http:
  base_url: https://XXXXX.duckdns.org:8123
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
When I check server configuration :
Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/fullchain.pem'
not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/privkey.pem'. (See /config/configuration.yaml, line 6).
Port forwarding on my box are OK (8123 to 8123)
My /ssl directory is empty.
Any help ?
Your ssl directory needs those two pem files in there. Those two config entries are looking for the files you’d have generated/exported as part of your cert generation.
My best suggestion is outlined in : -
Personally, my configuration.yaml has:
http:
   base_url: https://XXXXXX.duckdns.org
and my DuckDNS add-on configuration matches yours.
I will say, for the first time in a year using it, I had to completely remove the add-on and all associated dirs/files with it - reboot - login via local URL and reinstall it from scratch. Was a complete hassle (as nothing had changed), but back and working now thankfully.
You’ll also want to ensure your port forwarding is done correctly w/in your router - this is covered in docs / numerous YouTube videos.
Thanks for your reply !
Who generated this two config files ? (fullchain.pem and privkey.pem ?)
In all YouTube Tutorial or no one generate these files.
Hi Markus99,
I followed the DuckDNS configuration on HA page (https://www.home-assistant.io/addons/duckdns/#home-assistant-configuration)
http:
  base_url: https://my-domain.duckdns.org:8123
Is it :8123? Are you forwarding 8123 to 8123? Would normally forward 443 to 8123 and then not specify the port in the base_url
I just followed the documentation.
I will try to forward 443 to 8123 and then remove port in the base_url. Will see tonight :slight_smile:
That’s what I’m currently doing. Forwarding 443 -> 8123
EDIT: Original had typo SSL is port 443, not 433, corrected above.
Hmm ok I will try it, but why this should not work on port 8123 ?
Same with port redirection 443 to 8123 and with base_url in https://XXXXXX.duckdns.org
Any idea ?
Is this only when you are on your wlan? Does it connect if you are on 4G? It might be your router doesn’t support NAT loopback
Found my solution.
Redirection was working, I just regenerate a subdomain in duckdns.
I also change my remote and local port (for somes security reasons :)) and this is working fine.
Thanks for help !
