DuckDNS manual installation only
I’m kinda new to HA so forgive me if my question is stupid.
I run HA on raspberry pi through docker.
I want to enable speech to text so that I can send voice command using my android phone. After a lot of research I installed whisper and now I need to enable HTTPS so that the microphone can be used in Assist.
When I try to install DuckDNS I have to install it manually, apparently. When I search about it online, everything I find tells me the installation is done through the UI, with a lot of configuration possible.
However I only have this :
Screenshot 2024-03-12 at 08.27.16
So I tried to follow the manual installation anyway and I added this to my configuration.yaml file
duckdns:
  domain: xxx
  access_token: xxx-xxx-xxx
Then I restarted HA, but I dont see DuckDNS anywhere and I have no idea how I can enable SSL
Thanks a ton in advance
DuckDNS just gives you a hostname that resolves to your WAN IP.
You still need to:
  1. Get SSL certs
  2. Configure HA to use them
  3. Set up port forwarding in your router
This guide covers all of that.
I see everywhere that the DuckDNS add on should handle the let’s encrypt process.
My question is why can’t I install the DuckDNS add on from the UI ?
And why isn’t it being installed even though I added it in configuration.yaml ?
But you don’t have the add-on
Because you don’t use Home Assistant OS.
To get add-ons, use HAOS. With any other install method you can run software anyway, so there’s no need for add-ons.
There’s Docker images for LetsEncrypt, DuckDNS updating, and more.
Personally I use Traefik for all my remote access + SSL cert needs.
Ok makes sense, I’ll install things manually in separate containers then
thanks !
