Not really sure where to start debugging or what information you need, but should the SSL files above be created automatically or should I have added them myself?
Yes I have, I think I have done what is needed and I have tried to reinstall several times. So whatever misstake I’m doing I keep repeating
I updated the original post with the config for Duckdns. Do you see anything that is wrong? Shoud the files be added in the /SSL folder automatically? Are they generated based on the token or can I download a set of files from somewhere?
So after some restarts and reinstalls I got it to work. Only question is how do I access it locally now? Should I simply use the https://mydomain.duckdns.org since hassio.local:8123 isn’t working anymore?
What IP addres should I enter in the app? The Duckdns address or something else?
This is a really stupid thing, but thought i’d share in case anyone else has this happen. When I pasted in the token from duckdns.org, it copied with some whitespace at the front of it. Removing this and restarting duckdns, ssl files got generated soon after.
Great spot, I also got a space character before the token. Removed it, restarted duckdns, restarted ha, still can’t get the webhook to work, can’t see an ssl directory in file editor either…
