I don’t even know where to begin so, my up changes regularly and I have to manually change the up every time, DuckDNS isn’t doing it. any solutions
Do you have a service running inside your network to update that IP? Simply registering with ducksdns and creating a domain just provides a non IP address to use. You need to create a service to keep duck dns up to date.
What install method did you use?
I used hassio
Did you install and configure the duckdns add on?
Yes i did
