I want to secure Home Assistant internally so that browsers will let me use the microphone on my iPhone to give commands to Assist. Sure, it’s inconvenient to go to Assist and press the microphone button in the text box then speak a command, but I want to be able to do it anyway.
So I installed the DuckDNS Add-on thinking it would make the necessary calls to Let’s Encrypt to generate the certs, but it just won’t create the ssl folder with the privkey.pem and fullchain.pem file when I start it, nor do the pem files appear in the config or root folder. Here is my config for the add-on (domain name and token redacted):
I setup my internal router to send clients to the HA IP address, so that I can access HA by typing http://ha.mallonee.org (my domain) only inside my network.
Is there something I am missing? From what I have read, as long as accept_terms is set to true, it should just create the certs in the config folder or make an ssl subfolder with the certs there. Any idea why it won’t create the certs?
DuckDNS is not generating certificates. For that you need the Letsencrypt add-on in addition. And since the certificates are only valid for 90 days you also need an automation that renews your certificates automatically. There are blueprints you can use for renewing certs.
Or you subscribe to Nabu Casa which takes care for all of this. This is the easiest way.
I do actually subscribe to Nabu Casa. This might be a stupid question (I am an IT guy, but my knowledge of tls/ssl/https is admittedly a little fuzzy). I have a purchased wildcard cert from Comodo and applied it to my other subdomains/websites using a reverse proxy on a Kemp LoadMaster virtual appliance (but I can’t find my private key!).
But how does subscribing to Nabu Casa get you the certs generated?
@starob Kindly explain to the rest of the class how nabu casa will accomplish his goals of providing secure INTERNAL access. Did you even read the post?
Op - nabu casa doesn’t get you certs.
Why are you looking for the cert? You should simply specify their use in the config file. Then HA will respond to https requests instead of http. There is no need to actually worry about the file locations. This information is in the documentation for the duckdns add on.
Sorry for the confusion. I suggested Nabu Casa because it provides you with encrypted access to HA. That would allow @ScottCLT to use a browser for voice commands. For internal only SSL access you don’t need Nabu Casa and it will not solve this problem either.
