I can no longer use the HA companion app becauce Duckdns/lentecrypt is showing as not secure.
So I’m using
Rpi4
HA version:core-2021.7.1
DuckDNS version: 1.12.5
[10:24:14] INFO: Renew certificate for domains: #####.duckdns.org
abbotsleigh4.duckdns.org and aliases:
# INFO: Using main config file /data/workdir/config
Processing abbotsleigh4.duckdns.org with alternative names: ######.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Oct 9 09:26:03 2021 GMT Certificate will not expire
(Longer than 30 days). Skipping renew!
[10:29:18] INFO: OK
92.0.16.31
NOCHANGE
Any idea on how I can make it secure and use the HA companion app again?
Today is 07/12/2021.How did you generate a cert with the start date AFTER the expire date?? It is not valid until September 4th but then it is also expired.
OP, would you happen to have a “ssl” directory under “/ssl”?
The addon seems to copy the certificate to /ssl/<certfile>, so, as you specified “/ssl/” on the duckdns configuration (while it was not needed), I suspect your valid certificate / private key are actually in /ssl/ssl.
Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/ssl/fullchain.pem'
not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/ssl/privkey.pem'. (See /config/configuration.yaml, line 17).
Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/ssl/fullchain.pem'. (See /config/configuration.yaml, line 17).
I have managed to get the SSH addon to work and that shows:
ls
addons backup config media share ssl
cd /ssl
ls
fullchain.pem privkey.pem wireguard
