I’m trying to configure remote access using duckdns and I finally succeeded, however I can’t get it to work as a secure connection, only http, not https.
Have spent around 5 hours with minimal progress in trying to get this to work, i have mainly followed JuanM’s tutorial: https://www.juanmtech.com/hassio-duckdns-add-on-set-up/. Last resort… ask the question.
Here are my configurations:
'configuration.yaml':
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: myaddress.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
DuckDNS:
"lets_encrypt": {
"accept_terms": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
"token": "bf440686-820e-4a0a-bca0-bc7c39800ac8",
"domains": [
"https://myaddress.duckdns.org"
"seconds": 300
#INFO: Using main config file /data/workdir/config
+ Account already registered!
Thu Dec 13 16:27:16 AEDT 2018: KO
# INFO: Using main config file /data/workdir/config
Processing https://45bcrammond.duckdns.org
+ Creating new directory /data/letsencrypt/https://45bcrammond.duckdns.org ...
+ Signing domains...
+ Generating private key...
+ Generating signing request...
end of string encountered while processing type of subject name element #1
problems making Certificate Request
Thu Dec 13 16:32:38 AEDT 2018: KO
Thu Dec 13 16:37:40 AEDT 2018: KO
I checked that the certificates are there in the SSL folder and they’re definitely there…
I did restart yes, through the configurator I just clicked ‘restart hass’.
I can see in the duckdns log there was a problem making the cert request… but i’m no idea how to fix it or what the actual issue is?
The two certificates are .pem files - is that correct?
I’ve also tried having my external port as 443 in my port forwarding but no success there either…
i’ve stucked at this point for the last two weekends but now I FINALLY GOT IT.
the problem is the f router configuration.
First i had my 443 port redirected to the 443. with this forward the Duckdns start works fine and the configuration add-on was working well with https BUT the main page wasn`t
then I changed my 443 port redirection to 8123 and then “magia!”
http:
api_password: password1234
base_url: https://mydomain.duckdns.org:8123
and here my duckdns configuration (change your token and domain)
I’ve just setup duckDNS in hassio and it seems to be working as expected. I’m able to access the webUI with https, but my chrome browser still says the site in unsafe?? is this normal? I can see the certificate is there. Also when I access the webUI from within my local network I’m also getting the ‘site not secure’ message in chrome. Am I missing something?
I’m having the same issue and can’t, for the life of me, figure it out. I hate to have to forward ports on my router but apparently I need to in order to connect smartthings to my HA. I keep getting an error that my base url needs to be configured as https but it is so I’m guessing it’s not working because I still can’t connect to my HA using https on my local network or remotely.
I managed to get http working yesterday, both local and remote, by adding a host in the nginx proxy manager addon but no matter how I configure it I still can’t access through https. I get a “connection is not secure” error in Chrome desktop and mobile. I do have the duckdns addon working and I’m running all this on my Ubuntu desktop media server.
I have these ports forwarded in my router:
80>80
443>8123
8123>8123
Anyone have any suggestions? Is there something I need to do on Ubuntu to get this to work?
You need to provide some details. What are you using to setup your domain and SSL cert? What does you config look like? What address are you using to access. Check the logs for the addon (if thats what you are using) and HA to see what they are telling you and post up relevant info.
Same recommendation as above.
It may be better to start your own thread, when multiple people start posting on a similar issue it can be confusing as to what applies to who.
hello. I am running homeassistant on docker container on raspberry pi 3. I can access it from outside using http but can’t get it to work using https. I followed official link from homeassistant on how to setup tls/ssl, but I think they are talking about when you have homeassistant installed as standalone. anybody successfully installed tls/ssl over docker container in raspi ? thanks
