I have a Openreach modem (ONT) conecteed directly to my PT-Link AX5400 (Archer AX72). I use DuckDNS and the IP is set to the same as my ‘Internet IP Address’ is correct. I have Port forwarding setup to forward 8123 to the Raspberry Pi running hassio.
I am using https://MySubdomain.duckdns.org:8123 on my PC and mobile.
I can only access the above DuckDNS domain on my PC and when WiFi is on at home, will not work using mobile data.
Mybe I should give Home Assistant Cloud a go.
Ben
I am Using DuckDNS and the log has the folowing
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[19:58:38] INFO: OK
217.42.170.30
NOCHANGE
[19:58:39] INFO: Renew certificate for domains: zerodog.duckdns.org and aliases:
Processing zerodog.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Mar 9 21:11:13 2024 GMT (Longer than 30 days). Skipping renew!
[19:59:51] INFO: OK
217.42.170.30
NOCHANGE
And ‘NGINX Home Assistant SSL proxy’, I just restarted it and have the folowing log
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service crond: starting
s6-rc: info: service crond successfully started
