I recently moved to a new Pi, and everything was working fine (including DuckDNS). Now, I have a problem with the LetsEncript challenge. As the original domain was not correct I an trying to use a new one but it still does not work. I have the port forwarding pointing to the new pi (8123, 443 and 80).
+ Signing domains...
+ Generating private key...
+ Generating signing request...
+ Requesting new certificate order from CA...
+ Received 2 authorizations URLs from the CA
+ Handling authorization for YYYY.duckdns.org
+ Found valid authorization for YYYY.duckdns.org
+ Handling authorization for XXXX.duckdns.org
+ 1 pending challenge(s)
+ Deploying challenge tokens...
OK + Responding to challenge for XXXX.duckdns.org authorization...
+ Cleaning challenge tokens...
OK + Challenge validation has failed :(
ERROR: Challenge is invalid! (returned: invalid) (result: ["type"] "dns-01"
["url"] "https://acme-v02.api.letsencrypt.org/acme/chall-v3/431967910177/OLosIg"
["status"] "invalid"
["validated"] "2024-11-18T14:56:43Z"
["error","type"] "urn:ietf:params:acme:error:unauthorized"
["error","detail"] "Incorrect TXT record \"\" found at _acme-challenge.XXXX.duckdns.org"
["error","status"] 403
["error"] {"type":"urn:ietf:params:acme:error:unauthorized","detail":"Incorrect TXT record \"\" found at _acme-challenge.XXXX.duckdns.org","status":403}
["token"] "kVcZqL9AD1Dz_B7V2Cht33CoblbmTO-QneBXGUZ7Q4Y")
It works with the internal URL.
