Heads up, I am new to Home Assistant so please try to bear with me. I am running Hass.io on a Raspberry Pi 3B+ and I am following this guys configuration setup for my files.
So my duckdns server is giving me issues. It is opening very inconsistently and I don’t know why. I am able to open it 100% of the time on my local ip:
and I am able to open the add-ons through my local ip as well:
but when I go to open my duckdns website I am getting this about half the time:
and this the other half:
when I try to open my add-ons through duck dns I get a connection timed out error
My iframe_panel for Pi-Hole (the other add-ons are similarly structured) looks like this:
### pi-hole.yaml
# Adding an iframe panel for Pi-Hole
pihole:
title: Pi-hole
icon: mdi:block-helper
url: !secret pihole_url
and my sensor configuration for it (pi-hole is the only add on I am including a sensor with):
### pihole.yaml
# Pi-Hole is running as an add-on to the Hassio
# installation. It blocks ads on a network basis
# and enhances the privacy of my network as well.
platform: pi_hole
host: !secret pihole_url
# My Pi-hole has SSL enabled
ssl: true
verify_ssl: false
# The list below is actually every single value you can get from Pi-hole.
monitored_conditions:
- ads_blocked_today
- ads_percentage_today
- dns_queries_today
- domains_being_blocked
- queries_cached
- queries_forwarded
- unique_clients
- unique_domains
where !secret pihole_url
points to https://XXX.duckdns.org:4865
My http.yaml configuration looks like this:
### http.yaml
# All files amd data required data for
# the home assistant front end.
http:
# Password to protect Home Assistant
api_password: !secret http_password
# URL for my Home Assistant over the internet
base_url: !secret duckdns
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
where !secret duckdns
is https://XXX.duckdns.org
Like I said I’m fairly new to Home Assistant and everything so my mistake is probably something obvious to you guys. I tried to include as much information/pictures as possible but if there is anything else I need to include let me know!
