DuckDNS Setup Issue
I have setup DuckDNS on my home HA instance without issue. When I try to set it up on a remote computer in another state, I get the address validated on the duckdns site, and I copy the token into the configuration, however when I put in the address in the domain name field it won’t save it / blanks it out.
Both instances of HA are using the full fledged supervisor mode. I don’t remember having this issue in the past, and could use some help. I’m running this new instance on a Windows VM vs a Raspberry Pi instance on the first setup, that is the only difference in terms of setup
If anyone finds this later, I was able to get it to work by manually putting in the domain in yaml configuration
domain:
  - mydomain.duckdns.org
