i cant connct to hassio any more whit duckdns.
it worked very well but now somehing happend and i cant find what is wrong.
i already tried a new install andchanging the port and incert https:// but no change at all.
i search for answer but cant something egual .
this show up in the log
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[13:36:25] INFO: KO
Processing abc,duckdns.org
+ Signing domains...
+ Generating private key...
+ Generating signing request...
Error Loading request extension section SAN
548272361024:error:2207507C:X509 V3 routines:v2i_GENERAL_NAME_ex:missing value:crypto/x509v3/v3_alt.c:512:
548272361024:error:22098080:X509 V3 routines:X509V3_EXT_nconf:error in extension:crypto/x509v3/v3_conf.c:47:name=subjectAltName, value=DNS:abc,duckdns.org
The KO response from duckdns means it was unable to update your domain with your current IP address.
API password in http is now depreciated - you can’t use that anymore.
Do you have router forwarding setup for 8123?
I tried to connect to your http://89.180.68.73:8123/ but it won’t connect so I expect not.
