I am getting this error when trying to Start DuckDNS:
Failed to start add-on
Image homeassistant/amd64-addon-duckdns:1.15.0 does not exist for addon_core_duckdns
Any ideas? The add-on is not starting at all. Can connect to HA using local URL though: https://homeassistant.local:8123/
johnvpr
(johnvpr)
2
Same problem here, did anyone figured out how to fix it?
I CANT access HA with DDNS
however I CAN connect via https://homeassistant.local:8123
In my case I had to do 2 things:
- Remove the duckdns addon and reinstall it.
- Force the recreation of certs by first removing the existing ones. Apparently they were expired.
Followed these instructions: Duck DNS addon does not renew expired certificate · Issue #1955 · home-assistant/addons · GitHub
