I followed the instruction on https://home-assistant.io/docs/ecosystem/certificates/lets_encrypt/
Everything works fine, the only thing is that I have to add the port number to the url.
Did I miss something ? My provider doesn’t block port 80
Does it block 443?
If not, you set your port forwarding on your router from 443 to 8123 on your pi and there is no requirement for the port number.
According to the instructions forwarding port 443 would not be necessary, but i’ll give it a shot.
I can assure you it does say to forward port 443 to 8123, I wrote it
Step 5.
You are right, I didn’t read correctly. my sincere apologies.
