DuckDNS won't start
I am no longer able to login when I browse to my DuckDNS name. I get the login prompt, but it throws an “Unable to connect” error. If I browse to my IP then I am able to login. In the DuckDNS addon screen, it is always stopped, and it throws this error when I try to start it:
starting version 3.2.2
INFO: Using main config file /data/workdir/config
ERROR: Lock file ‘/data/workdir/lock’ present, aborting.
Is this the reason why I can’t login when I browse to the DNS name? And how do I fix this issue? I just upgraded to .62 from .60.1 with no change.
Thank you
