Hey,
The past year me and a couple of people over at tweakers build hardware to integrate your home ventilation system HA. I thought this was a good time to share and collect some opinions here.
There are several parts that where designed/build:
The Open AIR Mini:
This is a controller for your ventilation system. This will replace the current controller in there and use ESPhome to talk to HA.
Example integration:
Example of installation:
.Yaml Configuration: Github
This will allow you to use any sensor in your home to set the speed, read out the tachometer, turn your ventilation system on and off.
The Open AIR mini controller works with the following ventilation boxes:
- DucoBox Silent Standard
- DucoBox Silent Perilex
- DucoBox Silent Connect
- DucoBox Focus (warning Warning: Original Duco Valves are not supported! warning)
- Orcon MVS-15RH
- And more, more info here: Github AIR Mini
The original wired duco sensors are supported! you can connect up to two sensors to a Open AIR Mini. All RF sensors/remotes made by Duco/Orcon are not supported
More info about the sensors ( is the amount of times they can be connected to the AIR Mini):
- Original Duco RH (SHT-20) (1x)
- Original Duco Co2 sensor (2x)
- Open source RH (SHT 31) (2x)
- Open source Co2 Sensor (2x)
- Open source Co2 & RH (2x)
The Open AIR Valve
Since energy prices are skyrocketing in Europe right now, and we wanted to save as much m3 gas as possible we build valves that can be installed in Ducoboxes:
This will allow the air flow to be restricted to certain rooms. I use it in my house to close the living room ventilation when someone takes a shower. With a complete family showering the total ventilation time in our house was +1 hour on many days… During that time my living room was also ventilated… Now I can close the living room and save $ & the environment.
Image of a Valve:
Image of HA integration:
Each valve supports one sensor to be connected.
The valves can be used in the following systems:
The valves are printed in recycled PETG if you decide to build the valves yourself I / the world, would appreciate it if you use as much of recycled filament as you can =)
3D printed parts can be found here:Github
Assembly B.O.M:Github
PCBA Overview:Github
The Open AIR Foam
One of the Tweakers Forum members added foam blocks in their Duco systems to silence them. This hack/mod can be done very cheaply…
Before foam installation:
After foam installation:
More info can be found here: Github
Not all the Github pages are complete, and during the night/weekends we try to add as much information as we can. This will take some time… Everything will be available online! (schematics, Gerbers, B.O.Ms )
More information:
Open AIR Github repo:Github
3D printed files: Printables
Installation Manual AIR mini: Flamingo-tech
Installation Manual AIR Valve: Flamingo-tech
If you want one:
Air Mini:Tindie
Air Valve:Tindie
Air Co2 Sensor:Tindie
Air RH Sensor: Tindie
I’m interested to hear your feedback/ideas
The Flamingo
