Hello, I recently got my electric meter updated to a smart meter so now I can see daily consumption in their website. I have tried adding in the sensor to my config but it fails to run. Can anyone confirm it still works to start with and that its not broken, and any ideas from my logs below. Can find very little information on this when searching. Thank you
This is whats shown in my logs…
Error while setting up platform duke_energy
File “/usr/local/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py”, line 485, in wrap_socket
cnx.do_handshake()
File “/usr/local/lib/python3.7/site-packages/OpenSSL/SSL.py”, line 1934, in do_handshake
self._raise_ssl_error(self._ssl, result)
File “/usr/local/lib/python3.7/site-packages/OpenSSL/SSL.py”, line 1671, in _raise_ssl_error
_raise_current_error()
File “/usr/local/lib/python3.7/site-packages/OpenSSL/_util.py”, line 54, in exception_from_error_queue
raise exception_type(errors)
OpenSSL.SSL.Error: [(‘SSL routines’, ‘tls_process_server_certificate’, ‘certificate verify failed’)]
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 672, in urlopen
chunked=chunked,
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 376, in _make_request
self._validate_conn(conn)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 994, in validate_conn
conn.connect()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 394, in connect
ssl_context=context,
File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl.py", line 370, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File “/usr/local/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py”, line 491, in wrap_socket
raise ssl.SSLError(“bad handshake: %r” % e)
ssl.SSLError: (“bad handshake: Error([(‘SSL routines’, ‘tls_process_server_certificate’, ‘certificate verify failed’)])”,)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘www.duke-energy.com’, port=443): Max retries exceeded with url: /form/Login/GetAccountValidationMessage (Caused by SSLError(SSLError(“bad handshake: Error([(‘SSL routines’, ‘tls_process_server_certificate’, ‘certificate verify failed’)])”)))
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 442, in wait_for
return fut.result()
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/duke_energy/sensor.py”, line 28, in setup_platform
config[CONF_USERNAME], config[CONF_PASSWORD], update_interval=120
File “/usr/local/lib/python3.7/site-packages/pydukeenergy/api.py”, line 48, in init
if not self._login():
File “/usr/local/lib/python3.7/site-packages/pydukeenergy/api.py”, line 137, in _login
response = self.session.post(LOGIN_URL, data=data, headers=headers, timeout=10)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 581, in post
return self.request(‘POST’, url, data=data, json=json, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 514, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host=‘www.duke-energy.com’, port=443): Max retries exceeded with url: /form/Login/GetAccountValidationMessage (Caused by SSLError(SSLError(“bad handshake: Error([(‘SSL routines’, ‘tls_process_server_certificate’, ‘certificate verify failed’)])”)))
Connection lost. Reconnecting…
