First off, unless that wasn’t obvious, I’m pretty clueless about node-red. I use a certain module to control my old ABUS alarm system, because there isn’t any integration for it directly in HA.
There are basically three functions: arm/disarm/check status. I have set up inject nodes that call those functions in the node-red flow, and then a home assistant sensor node that let’s me check the state of the system in HA, and a debug node. So I can now arm/disarm/check the system from the node-red GUI.
In order to call the functions from HA, I have created three home assistant button nodes in node-red and then use the push.button service in HA to trigger the flows in node-red.
This obviously works, but seems clunky, and I have the nagging feeling that I’m not doing this the ‘right’ way.
Can anyone give me a quick smack around the head if I’m really doing this wrong?
This is how I feel, but I got over it after I understand this disorder is normal in nodered.
For this reason, I avoid using nodered at all cost.
It is my last option to make things working.
Don’t get me wrong… it is an excellent add-on and very useful, but I prefer using native integrations whenever I can.
For example, I prefer creating automations using the native integration.
You might separate functionalities using tabs and/or create good labels to make things a little more clear.
You could use the manual alarm control and watch for the alarm state to change to arm/disarm the alarm. Then can also set the state of the alarm when you check status.
+1 for MQTT. Easy to debug using MQTT Explorer stand-alone or add-on. Easy to control state (if needed and/or you choose to also use an MQTT Sensor) after HA or NR restart using retain. Easy to use from HA with a service call.
Personally I steer clear of the HA entity nodes in NR.
