Thank You much to Both for the feedback !!
… a bit more explanation of where I am in all this – I have found about HA very recently, and while I am not anywhere near set-up yet, I am trying to learn about it so I can figure out if it will do what I want/need. I have seen the HA-Blue and HA-Yellow hardware kits, and also understand that HA will run on any x86 computer, either natively (like in a RPi), or as a VM on a server machine…?
So now I know that the HA server will find my WAP (same VLAN/LAN) and communicate with my switches/sensors via the WAP. Have always wondered how HomeKit reaches my switches, is it directly via the WiFi in my iPad, or iPad Wifi → LAN via WAP → WAP to switches…
OK, I’ve read the suggested docs, and being brand spanking new to HA several questions came up, hope you do not mind I ask… I understood the difference between HomeKit Controller, and HomeKit Integration
a) Since I currently use Apple’s HomeKit app via my iPhone/iPad, I assume that to migrate to HA I will first have to go to HomeKit and delete all switches/sensors/scenes; and then implement all again in HA ? Otherwise, I suppose that there is no problem if I leave the HomeKit automation on, as the switches will get commands from both HomeKit and HomeAssistant …?
b) The document on Homekit Integration suggested above states that a FIrewall (which I have - pfSense) be set up to have open ports 5353-UDP and 21063-TCP. I assume that is access to the WAN, and wondering why this is needed ? Why does HA need to reach out to the internet for HomeKit, and what resources is it reaching out to ? Sorry to be seemingly paranoid, but after repeated hacking via my QNAP NAS apps, I am a bit of a Firewall control freak.
c) I also see, that the “Supported Components” list includes home alarms – which is AWESOME, as I have a DSC alarm system that I would love to integrate with HA. Lookks like I have a bit oif work to do to get it all together.
Finally, one automation that HomeKit does not have that I often wished for was ramdom switch on/off within a specified time window (say between sundown and 11pm). This would be very useful when away from home, to make it look like the house is still inhabited, even though no-one is currently there – not sure if this can be implemented with HA ?
Many Thanks again !
