Dummy "Home/Away" sensor
I would like to have a dummy On/Off (Home/Away) sensor that it’s state will be changed based on automations.
If no motion was detected by all of my motion sensors for X minutes, change the dummy sensor state to Away.
Then I can use the dummy sensor’s state for other automations like turning all lights off etc…
I am new to HA, and would appreciate your help.
How can this be accomplished?
Thank!
Take a look at this
From my experience, an home/away sensor based only on motion sensors is a bad idea. You will have wrong ‘away’ status. A lot.
I have a new entity! :slight_smile:
Is there a way to make it look like a sensor, and not a switch?
(currently I have a toggle button)
@Shaad Thanks for the tip. I will add more sensors to rely on. What is your current setup to avoid wrong "Away"s?
You can make a template binary sensor for that.
binary_sensor:
    sensors:
      at_home:
        friendly_name: "At home"
        device_class: presence
        value_template: "{{ is_state('input_boolean.at_home', 'on') }}"
That one did the trick!
Thank you all guys
I am having hard time making this presence binary sensor state to change based on PIR sensor activity.
In the automations I cannot choose an entity as an action, and this entity does not show up under devices.
Any ideas?
Can I maybe add the option for entities to be chosen as an action?
TNX
