The latest version of Uptime Kuma has added the ability to send a notification directly to home assistant. You specify a notification service and Uptime Kuma triggers a notification to that service. You can then use Event triggers to run an action based on that notification happening.
The problem I have is that this causes a notification, even though I just want to run the automation.
Is there a way of creating a dummy notification service that I can use with Uptime Kuma that doesn’t actually do anything - I just want to use it for automations.
Here’s the example from Uptime Kuma itself:
Trigger type: Event
Event type: call_service
Event data:
domain: notify
service: mobile_app_my_phone # change to your device name
service_data:
title: Uptime Kuma
status: 0 # 0=down 1=up
# name: Optional Uptime Kuma Monitor Name to filter by
Then choose an action, for example switch the scene to where an RGB light is red.
