I am trying to create an on/off switch which will run a script at each position.
Any help would be great.
Do you mean a HA script? Then use the Template Switch.
For bash/python scripts, use the Command line switch.
Thanks, but which value template do I use?
switches:
bedroom_light:
value_template: "{{is_state('group.all_switches', 'on') or is_state('group.all_switches', 'off')}}"
turn_on:
service: script.turn_on
entity_id: script.bedroom_on
turn_off:
service: script.turn_off
entity_id: script.bedroom_off
You need a template that returns True
(switch = on) or False
(switch = off).
Sorry, how do I do that? New to this whole thing
For example, when your script.turn_off turns a light off.
"{{ is_state('light.whatever_01', 'on') }}"
will return False
and the switch is off.
What if the script you want to run has no need to be tied to the state of a particular device? Maybe itβs just sending a notification of the current weather or something?
Is there really no way to put a button in the UI that simply runs a script?
Just add the script to your UI and you get an Activate button?
If you want a simple toggle, you can also use the input_boolean
component. Simply define your boolean switch, add it to your template, then add an automation for each state. There are some simple examples in the Input Boolean docs
