Greetings all. I am still a noob at HA, YAML, JSON, etc. Am trying to get basic system running with the components I need like Insteon MQTT bridge, ESPHome for ESP32 modules using only Native API, and 1-wire via host adapter. Have Hass.io 0.99.3 running on an ARM H5 based board. I have done extensive reading on all related to the components of interest and my head is spinning so please extend some mercy if I missed a clear answer posted or in docs. I have bolded 3 questions a bit farther down and the bulk of the .yaml etc is after.
I have some messages and items popping up that are related to my early efforts to get ESPHome working that I want to clean up. Entries when I go to integrations and open the ESP32 node with the …_2 and errors like :
Platform error light.monochromatic - Integration monochromatic not found.
Platform error light.binary - Integration binary not found.
when I check config.
These entries like this show up in integrations as entity Ids for devices that are working:
light.famrmtrayinnerww_2
light.famrmtrayinnercw_2
The overview page shows the devices named as set in the configuration.yaml file shown farther down.
I am not certain if I ever had MQTT in the picture for ESPH and at least for the moment I want to use the native API for ESPH comms.
As part of setting up ESPH, I named and configured 4 nodes for OTA programming in part to confirm I had a basic understanding of the process and that it was repeatable. Only one is active until I am more familiar with all related and have a clean core system. The others have configurations that are intended to be nothing more than place holders. I would like to avoid having to connect them via USB to reload.
Since I found reference to the …_2 issue here: Native API Component — ESPHome I thought this might help solve the problem but no. I am left with questions:
When the ESPH directions state:
In your ESPHome configuration! Not HA config!
1. Is this a file common to all nodes or is it the .yaml file specific to each ESPH node? There is no indication that I need to do ‘something’ for each ESPH node that I want to move from MQTT to the native API. I looked for a common file and didn’t find any that looked like good candidates.
2. My core.entity_registry is very small at the moment. Can I stop HA, copy/backup file, then simply edit the entity id to remove the [ …_2 ] and finally restart HA? More steps? There are no duplicates of the entity names (without _2) in the registry.
3. What have I missed (done wrong) that is causing the platform error on check config? The referenced devices are controllable from the overview page…
configuration.yaml
light:
- platform: monochromatic
- platform: binary
name: "Stairwell Night Light"
esphome:
platform: ESP32
board: esp32dev
wifi:
deleted
# Enable logging
logger:
# Enable Home Assistant API
api:
password:
ota:
password:
light:
output: gpio_17
output: gpio_16
output: gpio_19
output: gpio_18
- platform: binary
output: gpio_13
output:
- platform: ledc
pin: GPIO16
channel: 0
frequency: 30000
inverted: False
power_supply: power_supply1
- platform: ledc
pin: GPIO17
channel: 1
frequency: 30000
inverted: False
power_supply: power_supply2
- platform: ledc
pin: GPIO18
power_supply: power_supply3
- platform: ledc
pin: GPIO19
power_supply: power_supply4
- platform: gpio
pin: GPIO13
inverted: True
# frequency: 1000
power_supply:
- id: 'power_supply1'
keep_on_time: 0s
pin: 25
- id: 'power_supply2'
keep_on_time: 100ms
pin: 26
- id: 'power_supply3'
keep_on_time: 200ms
pin: 32
- id: 'power_supply4'
keep_on_time: 300ms
pin: 33
binary_sensor:
- platform: gpio
# device_class: none
pin:
number: GPIO34
mode: INPUT
on_state:
then:
if:
condition:
light.is_off: id_famrmtrayinner_ww
# Same syntax for is_off
then:
- light.turn_on:
brightness: 100%
else:
- light.turn_off:
Thanks for your help.
Q
