Duplicate / copy a Dashboard page
Hi there,
I would like to use different but similar “home”-pages for each device/user.
So first of all I defined a basic “home”-page in Dashboard, which I would like to copy/duplicate and later customize it for each user/device.
Is there any possibility for duplicating/copying an existing page?
cheers!
Sure. First create another dashboard. Open the Raw editor for your original dashboard (three dots menu twice), select everything and copy it. Open the Raw editor for your new dashboard, select everything and paste the copy over it. You now have two identical dashboards you can edit as you see fit.
So I copy the whole Dashboard?
What if I would like to duplicate only one page of the Dashboard?
You can’t assign a default view to a user. You can assign a default dashboard.
Sure, but I would like to control it about “visibility” of the page.
You can copy the individual cards from one view to another but there is no way to copy all of them at once, except by using the raw editor to carefully copy the section that has the view you want and to rename the view before pasting the copy back into the raw view. Make a backup of the contents (to a text file elsewhere) in case you make a mistake that prevents the views being shown.
Make a new empty dashboard. Give it a name.
Go to the dashboard you want to copy.
Click on the 3 dots. Edit dashboard.
Click on the 3 dots agian.
Go to rawdata editor. (not sure the name in englisch)
Copy al the data.
Go back to the new dashboard you have made.
Past the rawdata you just copied.
Save.
Enjoy :smiley:
I have a winter setting dashboard and a summer setting dashboard.
In the winter I don’t use my Jacuzzi :wink:
They wanted to copy a view, not an entire dashboard.
same here, to copy a full single page to a new page to have it like a DEV page bedore shuffling stuff on the original page, what i do now is create a new page called DEV, and copy paste all code single by single card
You can use the same Raw configuration editor. First, copy the whole thing into a text file as a backup in case you screw this up.
Then, Instead of copying the whole dashboard, copy one section of it, starting with “-title: ”. Make sure you copy all the way down to the -title for the next view. Paste it into the same page (make sure you get it in the right place) and change the values for -title: and -path:.
Wow that was a long echo.
That was exactly what was advised 7 months ago. Duplicate / copy a Dashboard page - #2 by tom_l
And yet again, they only want a single view, not the entire dashboard.
