Duplicate enties in integration
I’m not sure why all the ESPHome devices are duplicated like this:
Is this a normal behaviour ?
What HA version are you running?
I’ve seen this issue in 0.94 beta but it was fixed.
running 0.94.1 but I had this in 0.93 already.
Have you tried to remove the empty duplicates? (Trash top right after opening)
I’ve had the same thing happen before.
The fix is to just delete both of the duplicate entities and then just re-add the new one that gets discovered again.
Yes and then the non-empty one disappears.
I just updated one node to latest firmware, I will completely remove it and re-integrate it to test. I will let you know.
Ok, so far so good devices are not duplicated. I still have to try a reboot.
