Duplicate key
Hi all
Guess this is very simple coding for 90% of all of you out there, but ive tried sevaral hours and days and cant get this to work.
I get the error “duplicate key” because I have automation typed twice. But I need to include the automation.yaml to get the automation blueprints to work right? They get installed there when I program them…
I also need the automation for my IHC an bluesound typed in the configuration.yaml… I cant seem to move any of the two so I dont get the duplicate message… Attached the configuration.yaml below. it is the automation section the troubles me, where the two automations appear after each other.
Please help?
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
**[u]automation: !include automations.yaml[/u]**
**[u]automation:[/u]**
# Test notifikation
  - alias: test knap ved terrasse dør
      platform: state
      entity_id: binary_sensor.kontakt_ved_terrasse
      to: 'on'
      service: notify.mobile_app_pixel_7_pro
        title: Knap ved terrasse dør
        message: Knap ved terrasse dør blev tændt
    mode: single
# alarm! notifikation
  - alias: alarm aktiv
      platform: state
      entity_id: binary_sensor.alarm_aktiv
      to: 'on'
        title: Alarm!
        message: Alarm er aktiv
    mode: single
# Hoveddør åben notifikation
  - alias: doer aaben
      platform: state
      entity_id: switch.dorlas_40760667
      to: 'off'
        title: Dør låst op
        message: Hoveddør blev låst op
    mode: single
# IHC controller setup
ihc:
  - url: 'http:xxxxxxx
    username: xxxxx
    password: xxxxxx
    auto_setup: true
    info: true
    switch:
      - id: 40774930
      - id: 16072978
      - id: 2556946
    light:
      - id: 37703442
    binary_sensor:
      - id: 811612
      - id: 40678162
# Bluesound setup
media_player:
  - platform: bluesound
    hosts:
      - host: xxxxxx
      - host: xxxxxxx
Put the automation in your automations.yaml file. Not your configuration.yaml file.
Hi Tom.
Thanks for replying. Makes sense. But when indo the ihc and Bluesound comes up with an error.
Found out that it doesn’t charaterize as automations so left them out, and now it seems to work.
Thank you very much. Guess it was the simplest thing but for me it troubled me a lot and HA finally seems open for automations.
Yeah those aren’t automations, they are integrations, which belong in the configuration.yaml file.
