I’m getting this warning in a blueprint. I want to have choices from both device_classes when defining the trigger . Although I get a warning, the blueprint seems to work as I would like it to. I get choices for both motion and occupancy device classes when I use it. How should this be written to avoid the warning? I’m new to HA and yaml. Thanks!
Is that a trigger? Hard to tell without more of the code.
If it is a trigger, just do 2 triggers, one for motion, one for occupancy. I doubt that the trigger can take a list there, but 2 triggers should get you triggering when either one happens.
If it’s a selector, check the selector documentation to get the syntax right to put that into a filter.
Using the same key twice in any yaml construct is not going to work.
Thanks for your reply. I’m a newbie when it comes to YAML. It is in fact a selector. I found this under the Device Selector docs:
device_class device_class | list (optional)
Can be either a string with a single device_class, or a list of string device_class to limit the selection to.
So a list is optional. As a newbie to YAML it took me quite a while to find how a list should be entered in YAML. List is such a common term I kept getting all kinds of worthless matches to my searches. I’m a bit chagrined that it is such a simple thing. Once I found: https://docs.ansible.com/ansible/latest/reference_appendices/YAMLSyntax.html
It was clear. In my case:
I studied the selector documentation, is this what you mean? It seems there is more than one way to specify a list. I’m confused about the usage of dashes after filter:
