Hello. Clearly I have managed to louse up my configuration, but I am not sure how.
TL;DR
Hass.io (supervisor v140?), Raspberry PI3b, Home Assistant 0.83.1, zigbee2mqtt v0.2.0
sensors talking zigbee to mqtt to home assistant have nice “Friendly Names” but also have a set of “MQTT_Sensor” duplicated copies each.
I would like to remove the duplicates, ideally ending up with each sensor named something under my control.
Details
So I have a count of Xiaomi Aqara sensors talking zigbee to zigbee2mqtt talking to Home Assistant.
I have manually entered a “Friendly Name” for each sensor in zigbee2mqtt’s configuration.yaml, and sensors named for these appear in my history and I can attach groups to them, so that works nice.
But I also have a dozen “sensor.mqtt_sensor_$X” each with a friendly name of “MQTT Sensor”, showing as little red circles outside the groups in the image above. Ungrouped sensors show as red/blue circles with the friendly name - “router1”, “sense_door_1”, and so forth.
I suspect discovery and my manually entered values are fighting, but I am not sure how to fix things.
Back in 0.81, I only had one MQTT_sensor, so I set it to ‘hidden’ and carried on. But after updating to 0.83.1 and now I have a dozen or more so it may be time to fix things
Configuration Files
Main configuration.yaml:
homeassistant:
customize: !include customize.yaml
frontend:
config:
updater:
mqtt:
broker: core-mosquitto
username: !secret mqtt_core_user
password: !secret mqtt_core_password
discovery: true
birth_message:
topic: 'hass/status'
payload: 'online'
will_message:
payload: 'offline'
discovery:
- platform: "mqtt"
state_topic: "zigbee2mqtt/sense_thp_1"
availability_topic: "zigbee2mqtt/bridge/state"
unit_of_measurement: "°C"
icon: "mdi:temperature-celsius"
value_template: "{{ value_json.temperature }}"
json_attributes:
- "battery"
- "voltage"
- "linkquality"
- platform: "mqtt"
unit_of_measurement: "%"
icon: "mdi:water-percent"
value_template: "{{ value_json.humidity }}"
json_attributes:
- "battery"
- "voltage"
- "linkquality"
- platform: "mqtt"
unit_of_measurement: "Pa"
icon: "mdi:speedometer"
value_template: "{{ value_json.pressure }}"
json_attributes:
- "battery"
- "voltage"
- "linkquality"
# ... repeat about 15 times ...
# Cloud (google, alexa, etc integration)
#cloud:
script: !include scripts.yaml
group: !include groups.yaml
I am using groups.yaml to group the sensors into little cards. No lovelace (yet).
thp1_group:
name: Environment Sensor 1
icon: mdi:temperature-celsius
entities:
- sensor.sense_thp_1_linkquality
- sensor.sense_thp_1_temperature
- sensor.sense_thp_1_humidity
- sensor.sense_thp_1_pressure
zigbee2mqtt configuration json has {“homeassistant”: true, “permit_join”: false}
zigbee2mqtt configuration.yaml:
devices:
'0x00158d000234xxxx':
friendly_name: sense_thp_1
retain: true
homeassistant: true
mqtt:
base_topic: zigbee2mqtt
password: <password>
reject_unauthorized: false
server: mqtts://<ip>:<port>
user: <user>
permit_join: false
serial:
disable_led: true
port: /dev/ttyACM0
(I can grab the MQTT messages on zigbee2mqtt start if that is useful, I have resisted so far, to prevent wall-of-text syndrome)
Next steps
I have experimented with turning off “discovery” in configuration.yaml, but that seems to make things worse. I figure I should ask for help before I break things even more completely!
Does anyone have any suggestions for where I should look or what I should try next?
- Should I try to delete my manually created sensors from the main configuration.yaml and look for a way to discriminate the Friendly Name: “MQTT Sensors” and rename them something useful?
- or some other approach entirely?
Thanks!
