I’ve created a centralized monitoring platform with NodeJS and InfluxDB. Just point your Duplicati Client to the app’s endpoint and start collecting data
This is a self hosted app that can be built with Docker so everything can live inside your network. There is even a Home Assistant config to monitor stats on your HA dashboard
it’s still quite a work in progress and I’m still a beginner dev. The UI is basic but gets the job done, the real reason of creating it was to make a middleware API that could be easily read from HA or Grafana
