I have a Dupline Mastergenerator G3800 X015 with modbus support. I’m able to create a switch, which I can turn on/off.
Below you will find a setup of all 128 channels as a switch with verification of whether the swich is off/on.
This way you can “upgrade” your old dupline system to a smart home
You need a USB to serial RS232 cable and connect it in com1 on the master generator.
Hope this helps anyone with an old dupline G3800 X015 Mastergenerator.
Modbus - Dupline
modbus:
type: serial
port: /dev/ttyUSB0
baudrate: 111500
bytesize: 8
method: rtu
parity: N
stopbits: 1
message_wait_milliseconds: 40lights:
unique_id: dupline_a1
slave: 1
address: 12544
command_on: 1
command_off: 0
write_type: coil
verify:
input_type: discrete_input
address: 1536
state_on: 1
state_off: 0
delay: 2 -
unique_id: dupline_a2
slave: 1
address: 12545
command_on: 1
command_off: 0
write_type: coil
verify:
address: 1537
unique_id: dupline_p8
slave: 1
address: 12671
command_on: 1
command_off: 0
write_type: coil
verify:
address: 1663
state_on: 1
state_off: 0
delay: 2
state_off: 0
delay: 2
