via the Person functionality (via mobile app) I have the location history tracked and documented. For this purpose, I have stored different zones (e.g. home, work).
Is it possible to use the historical data and display how long I was in which zone per month or per defined time range?
Do you have a tip for this?
It seems to me that it would have been easier to realize if I had a counter that counts up the hours.
Thanks and best regards
Christian
Here is an example that sums up all the hours per month (as tom_l mentioned your recorder needs to be set up correctly):
Under your sensor:
- platform: history_stats
name: Hours in the office
entity_id: person.valentin
state: "Valentin Büro" # you need to specify a zone to track
type: time
start: "{{ now().replace(day=1, hour=0, minute=0, second=0, microsecond=0 ) }}" #current month
end: "{{ now() }}"
