Hi y’all!
I wanted to be able to monitor air quality in the Netherlands.
Luchtmeetnet provides an API to do this.
Next to individual readings (for instance NO2, PM10) I wanted a general index for air quality ( Luchtkwaliteitsindex). I’ve modeled this the same way Luchtmeetnet does (see here).
To be able to use this piece of code, you need to find a measuring station ID, from a station that measures the particle measurement you want. I use multiple stations because the station near me did not measure O3.
The easiest is to first find the station you want on this map. When you know the names, you can get the station ID with this url:
https://api.luchtmeetnet.nl/open_api/stations?order_by=&organisation_id=&page=1
Change the page number to find more stations.
Make sure the station actually supports the measurement you need.
After this, you can add to your HASS config, and change the station ID numbers:
- platform: rest
resource: https://api.luchtmeetnet.nl/open_api/stations/NL49007/measurements?page=&order=&order_direction=&formula=NO2
unit_of_measurement: µg/m3
value_template: '{{ value_json.data[0].value }}'
- platform: rest
resource: https://api.luchtmeetnet.nl/open_api/stations/NL49007/measurements?page=&order=&order_direction=&formula=PM10
- platform: rest
resource: https://api.luchtmeetnet.nl/open_api/stations/NL49007/measurements?page=&order=&order_direction=&formula=PM25
- platform: rest
resource: https://api.luchtmeetnet.nl/open_api/stations/NL49014/measurements?page=&order=&order_direction=&formula=O3
sensors:
airquality_no2_index:
friendly_name: 'Luchtkwaliteit NO2 Index'
entity_id: sensor.airquality_no2
value_template: >
{% set NO2 = states.sensor.airquality_no2.state %}
{%- if NO2 | int < 10 -%}
1
{%- elif NO2 | int < 20 -%}
2
{%- elif NO2 | int < 30 -%}
3
{%- elif NO2 | int < 45 -%}
4
{%- elif NO2 | int < 60 -%}
5
{%- elif NO2 | int < 75 -%}
6
{%- elif NO2 | int < 100 -%}
7
{%- elif NO2 | int < 125 -%}
8
{%- elif NO2 | int < 150 -%}
9
{%- elif NO2 | int < 200 -%}
10
{%- else %}
11
{%- endif %}
sensors:
airquality_pm10_index:
friendly_name: 'Luchtkwaliteit PM10 Index'
entity_id: sensor.airquality_pm10
value_template: >
{% set PM10 = states.sensor.airquality_pm10.state %}
{%- if PM10 | int < 10 -%}
1
{%- elif PM10 | int < 20 -%}
2
{%- elif PM10 | int < 30 -%}
3
{%- elif PM10 | int < 45 -%}
4
{%- elif PM10 | int < 60 -%}
5
{%- elif PM10 | int < 75 -%}
6
{%- elif PM10 | int < 100 -%}
7
{%- elif PM10 | int < 125 -%}
8
{%- elif PM10 | int < 150 -%}
9
{%- elif PM10 | int < 200 -%}
10
{%- else %}
11
{%- endif %}
sensors:
airquality_pm25_index:
friendly_name: 'Luchtkwaliteit PM25 Index'
entity_id: sensor.airquality_pm25
value_template: >
{% set PM25 = states.sensor.airquality_pm25.state %}
{%- if PM25 | int < 10 -%}
1
{%- elif PM25 | int < 15 -%}
2
{%- elif PM25 | int < 20 -%}
3
{%- elif PM25 | int < 30 -%}
4
{%- elif PM25 | int < 40 -%}
5
{%- elif PM25 | int < 50 -%}
6
{%- elif PM25 | int < 70 -%}
7
{%- elif PM25 | int < 90 -%}
8
{%- elif PM25 | int < 100 -%}
9
{%- elif PM25 | int < 140 -%}
10
{%- else %}
11
{%- endif %}
sensors:
airquality_o3_index:
friendly_name: 'Luchtkwaliteit O3 Index'
entity_id: sensor.airquality_o3
value_template: >
{% set O3 = states.sensor.airquality_o3.state %}
{%- if O3 | int < 15 -%}
1
{%- elif O3 | int < 30 -%}
2
{%- elif O3 | int < 40 -%}
3
{%- elif O3 | int < 60 -%}
4
{%- elif O3 | int < 80 -%}
5
{%- elif O3 | int < 100 -%}
6
{%- elif O3 | int < 140 -%}
7
{%- elif O3 | int < 180 -%}
8
{%- elif O3 | int < 200 -%}
9
{%- elif O3 | int < 240 -%}
10
{%- else %}
11
{%- endif %}
sensors:
airquality_combined_index:
friendly_name: 'Luchtkwaliteit Index'
unit_of_measurement: index
value_template: >
{% set NO2 = states.sensor.airquality_no2_index.state %}
{% set O3 = states.sensor.airquality_o3_index.state %}
{% set PM10 = states.sensor.airquality_pm10_index.state %}
{% set PM25 = states.sensor.airquality_pm25_index.state %}
{%set mylist = states("sensor.airquality_no2_index")|int,
states("sensor.airquality_o3_index")|int,
states("sensor.airquality_pm10_index")|int,
states("sensor.airquality_pm25_index")|int %}
{% if NO2 | int == O3 | int == PM10 | int == PM25 | int -%}
{% set Index = NO2 | int + 1 %}
{{Index | int}}
{%- else -%}
{{ mylist|max | int }}
{%- endif %}
I hope you like it, any questions of suggestions are welcome!
