claudiopi
(Claudio)
February 5, 2018, 8:06pm
1
I am new to Home Assistant.
I have the following DVR camera system in my home: http://la.dahuasecurity.com/download/DH--DVR5104%205108%205116H.pdf
It connects to 4 analog CCTV cameras (only 1 of them with audio) .
The DVR is connected to my lan with a fixed IP and Port
I then use the following software to access the cameras through the internet:
http://me.dahuasecurity.com/me/products/smart-pss-742.html
http://es.dahuasecurity.com/down.php?file=download/481334_dh_smartpss_international_is_v2.00.1.r.20170225.zip
I would like to integrate those cameras into home assistant.
Is that possible ?
Any experience ?
Thanks!
GBCRAS1
(Gbcras1)
February 12, 2020, 6:25pm
2
Hi.
Have you managed to add the Dahua DVR to Home Assistant ?
Good afternoon!! Someone could integrate a dahua DVR equipment with CCTV to HA
Following this subject up
in configuration.yaml add:
camera:
- platform: generic
still_image_url: http://YOUR_DVR_IP/cgi-bin/snapshot.cgi?channel=1
username: "admin"
password: "YOUR_PASSWORD"
authentication: digest
Sitram
(Adrian Martis)
November 17, 2020, 9:07am
7
I also have a Dahua DVR with 4 cameras connected to it. I was able to see all 4 cameras in HA by adding an entry like the one below for each one.
camera xxx
- platform: generic`
name: [Name of your camera]
still_image_url: http://[ip]:[port]/cgi-bin/snapshot.cgi?channel=[Channel]
stream_source: rtsp://[user]:[password]@[ip]:[port]/cam/realmonitor?channel=[Channe]&subtype=[0 - HD, 1 - low quality]
username: "admin"
password: "password"
Matteogolf
(Matteogolf)
February 20, 2022, 1:59am
8
hello, i’m trying your code but i get this error:
Error loading /config/configuration.yaml: mapping values are not allowed here
in “/config/configuration.yaml”, line 23, column 14
any suggestion?
Thanks,
regards
Sitram
(Adrian Martis)
February 20, 2022, 6:44am
9
Can you post your configuration?
jazzyisj
(Jason)
February 20, 2022, 7:16am
10
Have you tried out ONVIF? I use it for my Lorex system (made by Dahua) and it works well. Pulls in all the motion, tamper and alarms as sensors also.
Mikefila
(Mike Fila)
February 20, 2022, 9:11am
11
There is a dedicated dahua integration in HACS. Works with camers, dvr’s, nvr’s, xvr’s and doorbells.
It the downloaded zip file existed it would be great
