dwd-pollenprognos-card
A Lovelace custom card for custom component DWD Pollenflug in Home Assistant, based on isabellaalstrom/lovelace-pollenprognos-card
You need to manually move the folder pollen_img
directly inside your www
folder for the images to appear, or set the img_path
configuration value to
the prefix of the URL where the images are reachable.
Installation:
HACS (Home Assistant Community Store)
- Go to HACS page on your Home Assistant instance
- Add this repository (GitHub - bhuebschen/dwd-pollenprognos-card) via HACS Custom repositories How to add Custom Repositories
- Select
Frontend
- Press add icon and search for
DWD Pollenprognos Card
- Select DWD Pollenprognos Card repo and install
- Force refresh the Home Assistant page (Ctrl + F5 / (Shift +) ⌘ + R)
- Add dwd-pollenprognos-card to your page
Manual
- Download the ‘dwd-pollenprognos-card.js’ from the latest [release][release-url] (with right click, save link as)
- Place the downloaded file on your Home Assistant machine in the
config/www
folder (when there is nowww
folder in the folder where yourconfiguration.yaml
file is, create it and place the file there) - In Home Assistant go to
Configuration->Lovelace Dashboards->Resources
(When there is noresources
tag on theLovelace Dashboard
page, enable advanced mode in your account settings, and retry this step) - Add a new resource
- Url =
/local/dwd-pollenprognos-card.js
- Resource type =
module
- Url =
Example usage
Pick the allergens you want to display.
For ui-mode:
type: 'custom:dwd-pollenprognos-card'
region: 121
allergens:
- ambrosia
- beifuss
- birke
- erle
- hasel
- esche
- roggen
- graeser
For yaml-mode:
- type: 'custom:dwd-pollenprognos-card'
region: 121
allergens:
- ambrosia
- beifuss
- birke
- erle
- hasel
- esche
- roggen
- graeser
Usage in a view:
title: My awesome Lovelace!
resources:
- url: /local/dwd-pollenprognos-card.js
type: module
title: My view
cards:
region: 121
allergens:
- ambrosia
- beifuss
- birke
- erle
- hasel
- esche
- roggen
- graeser
Options
Name | Type | Default | Description |
type | string | Required | custom:dwd-pollenprognos-card |
region | string | Required | dwd region from which you have sensors - can be found at the end of the created sensors by the dwd-pollenflug-integration |
allergens | list | Required | List of allergens for which you have sensors |
title | boolean | Optional | Set to false to remove the heading from the card |
show_state | boolean | Optional | Set to false if you don’t want to show the state text under the images. |
threshold | number | Optional | Set to a number if you don’t want to show allergens below that number (set to 0 to only exclude unknown or i.u.). |
img_path | string | Optional | The URL prefix for where to find the images; defaults to "/local/pollen_img" ) |
Usage:
After installation, you can add the dwd-pollenprognos-card to your Lovelace dashboard using the sample configuration provided above. Customize the card by setting the desired options in your YAML configuration
Issues & Contributions:
If you encounter any issues or have suggestions for improvements, feel free to open an issue or submit a pull request.
