Dynamic home location
I am starting to evaluate Home Assistant for use on my live-aboard barge. In this use-case, I obviously would like to be able to dynamically update the system’s “Home Location” data, but these seem to be hard-coded in the system configuration.
I’m not happy about dynamically updating the config files and wondered if any experienced users have any suggestions on how to deal with this issue. Coding a solution isn’t a problem, but some pointers would be really helpful.
Thanks. PR
If you define the location in the UI then you can update the location with service calls.
